scootrs outboard disc brake
camel
scooter perv wrote:Its about 15-20 degrees which looks about right
oh and the hose is about 10 inches to long so even if I get it working I think im probably gonna have to buy another hose. Company selling them on ebay reckon theyve sold 300 of em and im the first to have a problem so either no ones complained or Im doing something wrong
hmm mine came with the exact same hose from uk based shop,i returned the hose explaining the angle was wrong and to be fair to them they replaced it with the correct type of 90 and 30degree fittings.i cant see the type you have any use at all
Craig H
Venhill are very good hoses, eBay Item or have a look at their eBay store you can get different lengths or try here http://www.venhill.co.uk/Hoses_&_Cables ... utch_Lines
Ye thats a standard scooter world reply
Sent from my GT-I9000 using Tapatalk 2
gunnerdaz
Main scooter: Lambretta Silver Special TS1
ArmandTanzarian wrote:Rotate the top hose 180 degrees, go through the headset that way and route it down past the throttle bar. Much neater.
i fitted mine this way, it does look a lot neater
mickdale
arent you weakening the handlebar casting by taking meat from the area where the throttle bar goes rather than the area that sits around the light unit?
nelson pk
On the bleeding question, are you closing the bleed screw before letting the lever return back? If you aren't it will just suck a lot of the air back in again.
Open bleed nipple just a fraction of a turn, pull lever in and hold, close nipple and let lever return. Repeat until you have a good brake. This should work.....if it doesn't you probably have a small air leak. Check for leaking joints.
I have known the master cylinder seals to be knackered from new because if the lever is worked without the brake fluid in it, it has no lube and the seals bugger up very quickly like this! Quite rare i believe, but it can happen!
