Schwalbe weatherman on tubeless
red
joeswoonara wrote:yes fitted some last night to be exact ...........if your`e on Facebook by any chance look up M.B.Developments page ,he has a good article on there about fitting Schwalbe`s onto SIP rims he pre-heats the tyre and can then fit them with just his hands and tyre soap ,no tyre levers !! i thought thats a good idea , so bought the required tyre soap ,warmed the tyre and it`s a piece of P**S .....GO FOR IT
How easy would it be to get them off again though?
joeswoonara
Main scooter: jet ts1
grayspeed wrote:Any ideas to the best way of preheating tyres? I've asked Mark, but no answer as yet.
if you read through his article he says he warmed them up on a oil filled radiator and or a fan heater .......or something to that effect
i cheated somewhat....... i pre-heated the oven ,removed all the shelves placed a block of timber in there and placed tyre on the wood , i turned the oven off first :lol: and just let the residual heat warm the tyre , the block of wood was to make sure it never touched any metal surfaces
i have yet tried to get them off ,but think it will only be a reversal of fitting them ..........and presumably if your trying to take them off they are going to be f**ked anyway so just cut them off ............
des
Just to up date i eventually managed to get one tyre on with alot of effort but i could not get it inflated with my 25 ltr compressor, tried the local garage no luck there.
So i brought it to my local tyre fitters he inflated it in no time and he also got my other tyre on the rim in two minutes and didnt even charge
    Users browsing this forum: Ahrefs [Bot] and 1 guest
