Clinder head gasket sealent
celt
Does anyone recommend a good cyl gasket sealant?
I have a skimmed and lapped head, I've used a small smear of Hylomar universal blue in the past but have run out.
Is there a decent alternative?
i use normal clear silicone
Ihateyoubutler
Thanks Shocky, I was about to ask the same question.
cezeta
shocky wrote:i use normal clear silicone
so do british bike builders to stop them leaking, b and q
RobD
Yambond or Hondabond. Available on ebay branded as threebond from memory.
RobD
An impossible task on most british bikes :lol:
Ditto 8-)
Stringy
Stag Wellseal is good. :)
J1MS
Ive used locktite for the last twenty plus years, before that I used to use gaskets that had a habbit of going pop if the Scooter was ridden too hard....Started using it after I ran a Yamaha DT175 piston with high comp head, the Locktite was reccommended by Dave Webster.....who was I to argue.... :shock:
sideout
Is Blue Hylomar recommended? :?
    Users browsing this forum: Amazon [Bot] and 11 guests
