AF rapido 225 infos
Ian Hepworth
cezeta wrote:just to correct 6LDA 28B, you will be changing to a 60mm stroke unless you plant to have your casings machines?
60x70 will give 231cc and will go together without too much fuss. the rapido as a 70mm pistoned kit will allow a number of oversizes up to 71mm and its oversizes. there after you could ceramic line to keep the 71mm bore
phone af rayspeed for prices, they DO the 225 as a classic. its whay 6LDA 28B has. The other one to consider is the mbd racetour kit.
read this months scootering as there is a good test with the kits.
What do you two call each other when you meet up at family parties etc?
damdam
Word of warning . . most 60mm cranks require machining of the crankcase as well . . . mine did.
Hi Special,
on AF website there's no information about this problem, what type of crankcase did you use?
thanx
Dam
Special X wrote:Word of warning . . most 60mm cranks require machining of the crankcase as well . . . mine did.
so I should expect to using a 60mm AF crank fitted with an RD400 rod, Rapido bored out to 71.5mm ? all on a Jet200 casing
What needs doing ?
Just a groove for the rod to run top and bottom ?
Train Driver
Ian Hepworth wrote:[What do you two call each other when you meet up at family parties etc?
The younger family member would never leave plush surrey to come up north to mid beds so we never have family get togethers :cry: :cry:
J1MS
One of my mates is also after this set-up 60 mm stroke on a classic Rapido 225, But after speaking to Ray Kemp he was told there were non (Classic 225's) available for the moment...... this was about Two weeks ago......Just thought I would mention this incase you were in a rush to get one.....
is the Classic 225 just a bored out Classic 200 ? isn't there a need to check clearance anyway ? obviously 4mm is one mutha of a rebore, but might be one way of doing it, if 70mm pistons are available, and the port timings wouldn't be too affected.
J1MS
byron wrote:is the Classic 225 just a bored out Classic 200 ? isn't there a need to check clearance anyway ? obviously 4mm is one mutha of a rebore, but might be one way of doing it, if 70mm pistons are available, and the port timings wouldn't be too affected.
I was lead to believe Classic 225 Uses different port timings... but Ray did offer to bore a 200 Classic and supply a 70mm Piston... My mate decide to wait for the 225, now waiting for a call back... :!:
cezeta
Hi Special,
thanx
Dam
i know the mec one in indian casings is ok and im assured the alpha crank is fine too. its down to how chunky the rod is, if it protrudes out of the webs too far then it will hit. the piston can hit the casings too, we took 2mm off dan startreams piston to be safe and it runs real nice although he uses 150 engine mounts :roll:
cezeta wrote:...its down to how chunky the rod is, if it protrudes out of the webs too far then it will hit.
so then it needs some taken out of the casing behind the crank..?
only sure way to tell is to build it up and check the clearance I guess, then strip it all down again if it needs some... :evil:
but I'll get the rod fitted to the crank first...
    Users browsing this forum: No registered users and 29 guests
