Diamond TV175 piston
ArKaTxU
Hi.
What do you think about Diamond pistons for TV175 engine?
They have 1,5mm x 2 rings.
I have a TV cylinder in 63mm and need a rebore, but I dont want go for Suzuki 64 piston still.
Thanks!
steve c
diamond pistons look very poor to me !!!!!!!!!!
beedspeed have some jap pistons
ArKaTxU
steve c wrote:diamond pistons look very poor to me !!!!!!!!!!
Less than 64mm?
steve c
Suzuki TS185 Piston Kit 64mm
Oversizes available in .5mm graduates. 64.5mm/65mm/65.5mm/66mm
The diamond piston will break up and destroy your barrel really poor, the gudgeon pin /wrist pin looked like a piece of all thread, threaded stud
tv175 can go 66mm plus from stickies book, so a few rebores
125cc outside dimension between 3rd and 4th fin 64mm
150cc between 3rd and 4th fin 69.5mm
real tv 175cc between 3rd and 4th fin 80mm
ArKaTxU
OK, thanks!
steve c
I have recently seen newer diamond brand pistons, with 1.5mm rings looked a lot better than the ones I had seen before, like the ones in indian ally kits
scooter restorations have them
Supereibar
I have used them in the past with good results. They are ok if you are not intending to tune the barrel to the tits
bristolmod
Supereibar wrote: They are ok if you are not intending to tune the barrel to the tits
Whats this Jaime?......................technical term? one up from a Stage 4? :D
Scootering since 1968.
Supereibar
You know it! :frog:
