removing headlight lens
sydduckett
Can anyone advise on the best way to seperate the headset glass from the holder on a series 3. Looks as though its bonded and dont want to crack the glass
ta
sef
Craig H
I used a dremel to do mine
sydduckett
Craig H wrote:I used a dremel to do mine
How does that work, you cant even get a stanley blade between the metal and glass?
ta
Craig H
The reflective part is held in with some white resin stuff just used a pointed grinding bit job done. Why do you need to separate yours?
Jazzy
I soaked mine in very hot water ,
Seemed soften it up.
Obviously make sure the lens isn't freezing cold.
DaveTomo
Main scooter: SX 200
I used a dremmel on mine also.Have an original carello headlight but the reflector was knackered/rusted/oxidised was advised it wouldn't pass the MOT with it.Used the dremmel with the grinding wheel and very carefully ground the metal down in a few places,enough to get a stanley knife the free it off the reflector.New reflector from scooter restos ,clear bathroom silicon , big heavy book on on it over night.good as new
sydduckett
Have been given a complete SX headset for a old seat and petrol tank i had. The Chrome surround is a perfect fit and in good nick but needs re-chroming, the reflector also needs re-chroming so was going to get both done at the same time.
I was hoping i could seperate the 2 without damaging the reflector and then put it back together once i had it chromed. I wouldnt have an issue seperating them with a dremmel or similar if i didnt want to keep the reflector but i do so i guess ill try and soak it an then try a new blade in there.
If i fail ill take it to wickstead tomorrow and try and find a matching reflector.
ta
Sidf, it is quite possible to seperate them without destroying either. The substance used to join then is some form of putty which will have set like rock. I seperated mine by gently prizing back the edge of the reflector (its folded over the putty) to expose the white putty substance. Then I used a selection of screwdrivers, knives, spikes and scrapers to dig the putty out. Took me an hour or so but the 2 parts seperated ok.
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 8 guests
