Rear Footpeg Problem
Bilko
Main scooter: LI150
I've been getting by with these rear pillion footpegs, but the half nuts aren't enough to hold and the footpegs keep turning. As well as this the left hand bracket can't be fitted straight because of the flywheel cowling.
Anyone any ideas which would be the best way to tackle this? The engine bolt is the longer type for the larger left hand mount.
New footpegs & footpeg mounts would be ideal.
Bilko's Oily Blog
Angry Bloke
What about a clamp around the mount ?
Bilko
Main scooter: LI150
I have 2 made for me by SLJ some time ago.
Not sure about how to sort pegs out though. :oops:
Bilko's Oily Blog
drill and tap the block areas on you mounts and mount the pegs to it, put on mount so pegs are to the rear of bike
Bilko
Main scooter: LI150
Good idea Mark, cheers. :)
Bilko's Oily Blog
scooterjet
Main scooter: Lambretta Series 1 TS1
Couldn't you get a new,longer engine bolt made so you could fit full size nuts and simply space the left hand bracket away from the cowling?
    Users browsing this forum: Baidu [Spider], Google [Bot], Semrush [Bot] and 17 guests
