Oil Level sight plug
paulmgreen
I see it all now..... ha ah ... pun intended....
Like the nog says.... they will just turn black! unless of course you change the oil after every run lol
as said... they look trick..... but can't help feeling a little bit pointless in a real world lol
www.JPPLambretta.co.uk
i actually think these are good............
after all ,most modern bikes utilise these............
and if oil is changed regulary at the needed times.........they will always be clean and visible............
if something is wrong.......ie metal/cork ware.......then visability will suffer..................
which then does give you warning to investigate/check inside.................. :D
Dazza
The only problem i've found since fitting it the other night is finding somehwere level to check/fill , stuck it on what I thought was a fairly level surface and topped up until i could just see the oil, check it this morning on another (checked almost level surface) and i needed to drop the oil I put in the other night :D
Bombay Mix Pilot
Hi, I fitted one of these years ago, works spot on, I change the oil about once a year and the glass aint got dirty. Usually I top up the oil to show in the window even up to half way and had no running problems at all. I reckon they are a great little item that saves all the mess etc of letting the oil drip down the side casing.
Cheers now
Andy
Dell Oughta
Bombay Mix Pilot wrote:Hi, I fitted one of these years ago, works spot on, I change the oil about once a year and the glass aint got dirty. Usually I top up the oil to show in the window even up to half way and had no running problems at all. I reckon they are a great little item that saves all the mess etc of letting the oil drip down the side casing.
Cheers now
Andy
I agree nice bit of kit 8-) All my bikes now have em
Mike
sion
who sells em
I got mine just last week from an ad on the For Sale section of LCGB boards
sion wrote:who sells em
"Late again" Paul on WKFA sc forum.
