Back Brake Pedal
jason frost
Heres how i fit them
first drill into the peg
then drill a 2/3mm hole at 90 deg to join up with the other hole
tap to M6
now heres the parts 2x front hub location washer 1x 12mm shim ( the one that goes over the clutch arm o-ring ) 1x M6 repair washer 1x grease nipple
hub washer first
pedal then the other hub washer
shim washer, you may need 2 to take up the play
and last the repair washer and grease nipple
And heres how to sort out a worn peg
first cut it off
drill and tap to M8
then use a back brake pivot bolt
the replace the peg
bristolmod
Clever................like the rear brake pivot bolt idea.
i'm never too old or senile to learn about Lambrettas :D
thanks
Chris
Scootering since 1968.
TS1-200
I like it, brilliant.
Keep on keepin on
another good guide.
yes, use of the rear brake bolt is a good one
thanks for sharing 8-)
J1MS
.....Brilliantly simple..... 8-) 8-)
red ghost
Main scooter: lambretta gp150
I can sense a book comming along...
rog60
Main scooter: Indian GP200
Flippin' brilliant. Some time ago I wondered how that could be done without welding a replacement on.
Got any similar ideas for replacing the battery tray without welding :?: :?: :?:
LI150
Main scooter: Series 2 LI150
Top ideas keep em coming........... :bouncyeng:
andylaw7
very good /innovative /splendid idea /super /smashing / great :o
excellent tip there Jason..................and good pics.......
have done that myself many times..............and works very well..........saves welding a new pin in etc............. :D
