Lambretta Tool box lock rivets
mrsheen
Main scooter: Lambretta Li125 Series 2
Same as before, im restoring/rebuilding my series 2. Had to buy all new locks and looking for suggestions on how one goes about securing the rivets.
I have the two rivets required however never done this before. Is there a special tool for this or some kind of punch?
Do i need a vice?
Really want to do this the right way.
Any help much appreciated
Sy
You will the gun type tool to fit the rivets.
Sent from my GT-I9000 using Tapatalk
WINTERMODEL150
mrsheen wrote:Same as before, im restoring/rebuilding my series 2. Had to buy all new locks and looking for suggestions on how one goes about securing the rivets.
Do i need a vice?
Sy
I take it you have the type of rivets that need banging over?if so I use piece of round nylon bar with a countersink in one end this holds the domed part of the rivet securely in place, then you need to tap the rear of the rivet over with a small punch and a small hammer until its tight.
Dean
onefortheroad
Main scooter: Li125 series 2
WINTERMODEL150
onefortheroad wrote:This is what you want.
http://www.richpresley.co.uk/lambretta- ... l-43-p.asp
That's the one :D
I think Craig Robinson had a good idea over on the LCGB web site and replaced the rivets with little domed nuts. Looks quite good I think and you have the advantage of being able to swap the lock should you wish.
Glue it! :lol:
mrsheen
Do i need a vice?
Sy
Dean
Thanks dean, this is the rivet ill be using is from Beedspeed.....is this all i need?
WINTERMODEL150
Do i need a vice?
Sy
Dean
yes, but remember if you slip then you will need to paint the toolbox door again :cry:
Don't glue it like soulsurfer suggests I think he's new to this game bless him :frog:
Dean
I was just kidding about the glue here, save that for the badges ;-)
The nylon bar thing is good, but there are various grades and it'd have to be hard, I have the RP tool above but the last one I had I sent to Jem to be done :-)
    Users browsing this forum: Google [Bot], Semrush [Bot] and 85 guests
