Foam filters
faf
Main scooter: GP 230 Mugello
Hi,
What oil should be used on a foam air filter?
Cheers.....Steve
faf
Cheers! :)
Lamaddict
How important is the oil on the filter? I'm thinking with all the oily crap that generates around a Lammie engine with the panels on some of that would stick to the filter :?
faf
Well,from what i`ve read/led to believe,it`s the oil that prevents crap entering the carb not the foam! So i guess when fitting a new one or after cleaning its a good idea to coat it with oil!
Tommy Boy
Main scooter: Series 1 with a Twist!
Once you see the shite that flushes out of a foam filter dont think I would go back to an open carb set up.
I clean mine with white spirit and re-oil with the stuff recommended above. All I can say is that from experience I find the foam filter traps more crap with oil than without.
M.D.M.A. Scooter Collective
