petel for RB
rb22
Main scooter: li rb230
does anyone know can i get stronger petels for RB and were from ? :wtf:
Darrell Taylor
Main scooter: LAMBRETTA
reed sheet is available to cut your own petals in various thicknesses,i have a few to go at
although the rb petals suffer from another problem to cause failure in that they touchdown onto the casting which can be remedied with porting
also a misfire from a faulty ignition or even a fouled plug can cause reed failure.
mcbrid
(a misfire from a faulty ignition or even a fouled plug can cause reed failure)
Oh yes it can!
On way to Brid had a massive backfire when the plug cap popped off then on again. Apparently flames out of the end can!
Result broken reed petal and dead RB22.
Fortunately I was only 3 miles or so from AF and after a slow tow from Eston Rifle 81 and the Rebel, Ben sorted it out for me and I was back on the road again.
Top job young Mr Rayspeed!
:anbrgin; :anbrgin;
mickdale
is there a specific stiffness that is ideal for reed petals?
rb22
Darrell Taylor wrote:reed sheet is available to cut your own petals in various thicknesses,i have a few to go at
darrel were do i get reed sheet from pal am from wakefield
Darrell Taylor
there are various suppliers who could provide you with reed sheet
i do have some if you need some,im in doncaster
a thicker reed on the outer petal will help reduce failures
reed thickness can be calculated to suit engine specification but as a general rule thinner petals for response/power thicker petals give good reliability and still good power although 0.25mm is thin for a 50cc at 14000rpm and 0.4mm could be described as thin on a 250 at 9000rpm
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 2 guests
