PK forks in an SS90
...you need the pk -xl forks with the larger spindle and swinging arm...they go straight in same bearings and length...you'll need to modify the steering lock cut out...and as stated mudguards gunna need a bit of fettlin'...
have a look at proboards small frame forum...don't know how to show a link
there's loads of knowledge on there....
what you up to now?
what you up to now?
- jonny snatchsniffer
pk125 forks are what you want if you are fitting a disc, stay clear of xl2 forks as these are threaded all the way up like a t5 so you will need to fettle them of weld on a different stem
have a look here http://davedaniel.proboards.com/index.cgi?
