Pictures of Lambretta Super Monza Kit.....
Chris CSPE
No nipped oil seal, no seal to replace,no worn out bearing if petrol gets to it. A more reliable engine, my old MB YZ engine was done like it.
lamy150
nelsonpk wrote
I guess it comes as no surprise to anyone that i agree with most of what Johnny says.
I just wanted to add that i dont think there are any outrageous claims being made like some may suggest. We all know that anything mechanical can break but some mechanical items are more reliable than others.......for example a standard vespa compared to a Lammy.
Sorry guys, i love lammys but its true!
I'm going to leave it now for the dyno, people who run one and buyers to decide how good it is and i guess thats how it should be!
didnt i hear somewhere that 1 or maybe 2 of these were (standard P2's) actually leading
for a good distance in the endurance 'race'
Muppet
it makes for a cooler running bearing than a bearing running in grease between two seals; just looked at the pics again the reed looks very much like a std TZR 125 reed block; why not the much talked about V force reeds or is it tassinari; thought they were what we needed for speed,
muppet,
C’est la vie
Lamaddict
There are other kits to consider aiming at the touring market - Avanti, MB RT even the DAC. All probably less expensive in the long run. I'd love to see them all toe to toe with the Super Monza over some sort of time trial.
CE seems and shows he's good with all his track wins and the latest time trial win in Spain with the SM but I've never had much luck with some of Cam Lams products. The Mugello with all it's different editions seems to have more coverage than most on these forums...
Chris CSPE
JB tuning also use this type of bearing in some of there engines to, for some time now.
nelson pk
sean brady scooters wrote:i,m a bit suprised that no one has mentioned or picked up on the flange modification as regards this kit ...
I just wondered if anyone on here has tried or done that before cos i havnt., I presume it means doing away with the inner seal and just letting the petroil mixture lube the flywheel side bearings just like on older li,s..
apart from slightly less losses due to friction /drag , whats the gains/benefits if any ?
Well Sean you and Dan seem to be more up to speed with engines than anyone else on here. I'm not being sarcastic or anything here and thats the truth! I value your opinion. Any ideas?
I for one am not sure.......could it be that the grease eventually burns away after a certain mileage and the best solution is to constantly lubricate that bearing? I have always thought that may be a weak point on a Lammy as with a vespa the flywheel side gets constant lube but with a Lammy its just left to the initial grease that is put there when you rebuild the engine and surely this must eventually burn away in a high performance engine?
jonny snatchsniffer
well bearings can run at a higher speed when lubricated by oil and you wont have to repack with grease, it might use a bearing not meant to run in grease
Diablo
Also good way to reduce primary compression.
Diablo wrote:Also good way to reduce primary compression.
i think the position of the reed will go some way to redude pcr as well
any way guys ...i think your all just gonna have to wait a while for some feed back on this kit ....
but ....i will say if i had the cash ....i would :D
ktm bearings are also petol /oil lubed. looks like lambretta had it right on the early series 1
