YZ250 conversion
cut it further back and make wheel base longer this will help on fast pullaways :o :P
tonydevon
Main scooter: '71 GP125
that would help with the increased wheelbase, but I think it ruins the lines and proportions of the scooters when the bike engined versions, have the engine shoved right back out the bodywork
well there was that black gp in scootering a good while ago that had the motor pushed back a few inches ..it actually looked very good
Chris CSPE
I had a GP with carbon body work,the engage was over 30hp and a bit of a hand full under hard exceleration, the engine mount tube and the shocker pin got moved back 6 inch. The area around the number plate was cut out and a strip of metal about 3 inch added on then the piece that was cut out was welded back in-place. The handling was improved no end, not just when excelerating it just felt better to ride. You couldn't notice at first that the wheel base was longer. (full bodied) the air filter sticking out the middle of the side panel was a bit of a giveaway though.
That was this one Rickspeed.
tony
Main scooter: 90ss
if you lengthen the wheelbase you will slow the turn in. It then begins not to feel like a scooter. you get more stability for certain. But the bike can feel lethargic if that is the right word. Not fun to ride if you like corners. You also are moving an already rear weight bias machine further into that zone. Dont think is necessary tbh.
drew2
frame is now cut,i thjnk rocho's done a great job with the plasma cutter,
new mount is in the frame ready to take the engine
the engine will sit back about 50mm
drew2
the awesome psycho gp,excellent bit of kit,hope this turns out as well
Chris CSPE
tony wrote:if you lengthen the wheelbase you will slow the turn in. It then begins not to feel like a scooter. you get more stability for certain. But the bike can feel lethargic if that is the right word. Not fun to ride if you like corners. You also are moving an already rear weight bias machine further into that zone. Dont think is necessary tbh.
Did I say 6inch or 6ft,
Drew it's great to see all the progress being made, looks great.
yeah that was it ..couldnt for the life of remember what it was called ..any pics :D
Chris CSPE
No probs Eden.
Drew, wot happened to that frame I lent ya! :lol: :lol:
