Jap pistons
AUSSIE
Does anyone know of a catalouge or data base of jap pistons that lists diameter, pin size position of ring pegs and if there are reed valve windows.
I'm hoping to do a budget tune on a sil barrel or maybe those cheap ali ebay jobbies but asso pistons are the best part of £100 so I've been looking at mitake and prox pistons but cant fine enough info.
Help please!
J1MS
AUSSIE wrote:Does anyone know of a catalouge or data base of jap pistons that lists diameter, pin size position of ring pegs and if there are reed valve windows.
Help please!
Wisesco list sizes on one of there web sites... But the First catalogue I got with detailed piston dimentions was from Grampian motorcycles Musker st, Crosby. they used to be in Bootle Liverpool. They are one of the biggest stockist of Motorcycle pistons in England if not Europe....They stock Mitaka and Prox...
Knowledge
The Hi-Level catalogue is excellent, but it is only available to dealers and the book is HUGE (like 5" thick). Lots of info including compression heights and ring thickness etc etc
Martin
AUSSIE
Would these stockist be willing to let me get access to one of their books? even if it was an out of date one?
If the pin diameter is 18mm what con rod can I use with Indian crank webs?
Knowledge
I have only ever seen the hi-level book at the discretion of motorcycle shop owners. They have an annoying habit of throwing the old one away as soon as they recieve the new catalogue. Frankly, there are no motorcycle shops in the country big enough to store TWO Hi-level catalogues.
There are several options for con-rods that suit 18mm gudgeon pins. I think the Vespa APE rod is common, as is the Rotax rod, but I know that Harry Barlow has some 116mm rods that take a 18mm gudgeon pin. Harry describes this as the holy grail of gudgeon pins. Nice one Harry.
There will be other people along in a moment with more suggestions of rods. If not, start a specific thread.
Martin
Rude De
Main scooter: 69 Gp 200 65 Tv 200
http://www.pro-x.com/eng/default.htm
Load the tech pdf for the circlip and print out the sizes and part #
use it as a key for the other pdf catalogs it tells you the piston sizes not the wrist pin sizes but gives the part # for the circlips
wiesco catalog
http://www.who-sells-it.com/cy/wiseco-p ... g-475.html
More conrod options
http://www.hotrodsproducts.com/index.cf ... cts.search
Markus
Try TKRJ http://www.tkrj.co.jp/
Many Jap. pistons an conrods with all dimensions you need.
    Users browsing this forum: Majestic-12 [Bot], Semrush [Bot] and 8 guests
