Roller type bearing conversion
ArKaTxU
Hi.
Someone know something about a roller type bearing in the Lambretta drive side?
A friend tell me something about this conversion with engines with more than 25hp :roll:
Thanks!
tony
Main scooter: 90ss
you will need a ball type bearing in there to locate the crank and keep it located... unless its some made special brg I have never seen. If you have roller bearing both sides what keeps the crank stable and in-line?
ArKaTxU
tony wrote:you will need a ball type bearing in there to locate the crank and keep it located... unless its some made special brg I have never seen. If you have roller bearing both sides what keeps the crank stable and in-line?
Hi Tony, thanks for your answer.
Its possible that this conversion is with a pin type bearing?
Thanks.
    Users browsing this forum: No registered users and 30 guests
