Piston options for 186cc reed valve cylinder?
ArKaTxU
Hi.
What are the options now to convert a TV175 cylinder to a reed valve?
I need only a piston.
Thanks
CPH Lambretta
Main scooter: DL 150 1970
Mitaka ,the same one used in the GT 186 kits
Slow is the new fast!
Stokie
as above
Yamaha RD 350 piston (64mm bore)
Not sure what rod you'd need though - possibly standard 107mm
bigmuff
Main scooter: matt black indian gp
Stokie wrote: as above
I have just done a RD350 piston conversion on a SR175 barrel using 60 x 107 crank. I got 3mm taken off base off barrel. I think the TV 175 used a 58 x 116 crank. Would this mean you would need a packing plate? 6mm?
soullad
Have you a standard TV ( 58 x 116 mm ) crank already fitted Ackba?
ArKaTxU
soullad wrote:Have you a standard TV ( 58 x 116 mm ) crank already fitted Ackba?
Thank mates!
No Ian, I have the TV barrel but still I dont have the crank.
ArKaTxU
Are you sure that youtake off 3mm with 60x107?, its possible that you have 60x110?
bigmuff
Yes definately took 3mm off the base of a standard length barrel (101mm). I think if you use a 110mm rodded crank with a std barrel you dont need to remove anything.
I am sure I have a 60 x 107 mec crank. I only bought it earlier this year.
ArKaTxU
bigmuff wrote:
ArKaTxU wrote:
bigmuff wrote: I have just done a RD350 piston conversion on a SR175 barrel using 60 x 107 crank. I got 3mm taken off base off barrel. I think the TV 175 used a 58 x 116 crank. Would this mean you would need a packing plate? 6mm?
Ok.
soullad
Admiral - you need to find out what the compression height is for the RD 350 piston. Then you can work out what rod length / crank / cylinder machining best suits your intended set-up and pocket.
    Users browsing this forum: Amazon [Bot] and 11 guests
