new 5/6 plate clutch for lambrettas
handofdave
Main scooter: li ts1
any more updates on availability?been getting desperate and started to look at the usual dealers clutches again but want to avoid a 2nd mortgage
cheers
rocho68
handofdave wrote:any more updates on availability?been getting desperate and started to look at the usual dealers clutches again but want to avoid a 2nd mortgage
cheers
hi dave , again sorry for the delay , pm me with the details of what you need and what spec engine you run , mark whos running the dac has now fitted the finalised design and it will be run this saturday followed by the rally to ireland next week , i have recieved a small quantity of my steels that i ordered so i can get on with machiing some up , i also have photos to go on the site tomorrow of my new "normal power " lambretta clutches again sorry for the delay !!
took scoot out today and did around 75-85 miles at all speeds and conditions (town and dual carrigeway), i even held it for 10-12 miles at 85mph and i found this clutch as good as i hoped it would be , its as easy to pull in as a std and can cope with as much grief as you can give it.
i am amazed by the ease of how it handles all thats thrown at it.
thanks lee :P
roll on ireland as the final test 8-)
joespeed
cheers
hello rocha68.
mark has just put a report on here about the clutch and i would like to order a couple if you can supply them,
regards
joe
rocho68
heres my new "normal power" clutch (cr2) which is aimed at standard to mildly tuned bikes , it currently being fitted to my 24 bhp engine so we will see what happens ! , i think pricewise you will be looking at around £150 , as for by 6 plate full power (cr1) im currently sorting the first ones out :D
Rich_T
Main scooter: Li Special
Looks smaller than RS125 plates and 8 tabs.
Are these clutches now based of Lifan 125cc Monkey bikes parts like the Siagon one?
soullad
Lee,
would they work with a standard Li type plunger / chaincase set -up.
Ian
quick update i pulled my motor today to change the drive side oil seal and thought i would check the clutch out while i was in the motor, i am pleased to say there was no wear at all after a very hard 600 miles on final finished unit
roch68's clutch after 600 miles with no wear by mark & anne's photos, on Flickr
on a by note the readspeed 6 plate i was running needed changing after 500 miles as it was worn out , saying that jerome did say that its not designed for a 40bhp motor so i was happy to change as and when i needed to.
Any updates on these?
rocho68
corrado wrote:Any updates on these?
hi corrado , after several problems with supply / home etc im finally back up and running , there are some new design features which include an all new cast aluminium basket currently being made to my design , a new lazer cutter is also in place as the last one proved to be slightly unreliable !
as for the five plates , i have a few now in tuned bikes with no issues that im aware of and the 6 plates in the dac lambrettas , so fingers crossed everything now will start progressing !!!
cheers lee
