my scoots-my history
a7grenade
Main scooter: 1963 Li150
other projects took over;
and current daily money pit
but son dragged out boxes every now and then and eventually doesnt bother waiting for me-he starts where we did;
with aid of stickys (in my day we had the little ring bound lambretta manual which fell apart-)
we mocked up a few ideas as he went !
remarkably, despite the piston being seized solid in the old 1979 serveta engine, we bought a rough (very rough cast off ebay) 185 barrell and piston kit (well you have to go bigger dont you) and i spent some time porting it; bolted it on and proceeded to push it up and down the road all evening (ide cut of the kickstart back in the day) bloody thing only went and ran!
one of the best days of my life thanks to my boy.
clutch soon seized on despite me soaking it for week or two-but it sorted itself and its good for a last up and down the road once a week. even bolted on the carb without setting up-although the tap was gunked up a bit after 30 yrs in a box!
http://youtu.be/POtUT0xPNxo
using just the bits in the garage he came up with this
then my best mate died all of a sudden, he had restored this
and then more recently a red and white serveta which his missis still has and was about to do this;
and that spurred me on a bit!
weve mucked about with various versions of cut down but now headed toward panels back-which is tricky as i had cut off everything
ive toyed with the dream of full 80s metalflake slim style
but keeping to a budget we are heading toward a s2/s3 hybrid;
i love this
my loop is soooo cut down and ive been trawling the ads for a s3 loop and carbon f/glass versions etc to no avail
had a chat with frank at lam innovations (what a nice guy) and come up with a plan to use a f/glass s2 loop on a new framework as he has done for others/auto conversions, but with s3 front end
so ive sourced some rough/old legshields/good mudguard/headset and looking out for s2 rear boards and side panels then its off up to frank to get some framework welded on-cant wait
ps, if anyone has old s2 side panels/rear boards?..........pls get in touch-cheers
loving the forum
j
a7grenade
RICSPEED wrote:i bet your mum was thrilled to see you had cut down her vw baja style :lol:
any way you could make pics bigger ??
will try to scan them again later
love to have a play with the austin 7 type things they look like fun ,
ill have dibs on the bars and gear change if you dont need and if you search on here theres a guy doing fibre grass series 1 and 2 parts that look good
btw ..had seen the vid as it seems i have commented on it :D
http://www.bpm-grp.co.uk/picture-gallery.php
found these pics for you ..a series 6 frank did ..
if you are fitting series 3 leggies to yours then you will need series 3 rear runners are the s1/2 ones wont match up and will need to close the gap in the side panels also
a7grenade
ok, thanks for pics and i will bare in mind your offer-cheers (have dave webster 1980s rear set also)
frank said the same thing about the runners but i was wondering if its just the width difference?
was thinking maybe the runners could be cut and shaped at the front if legshields are narrower
was about to post for some dimensions from someone
i just quite like the s2 runner shape and it matches the panels
the f/glass panels are the cheapest option but again wondering if that asking for trouble having all that plastic????
thanks for feedback though-lovin these forums :biggrin:
gtwildcat
Main scooter: lambretta GT200
Nice wildcat seat! Wanna sell it?
a7grenade wrote:ok, thanks for pics and i will bare in mind your offer-cheers (have dave webster 1980s rear set also)
just the edge is far more square ..a bit of 4mm rod welded to the edge would help but good rear runners are a bit steep on ebay to go cutting ,try extending series 3
btw ...did you see the link above the orange scoot ??
a7grenade
yes did, many thanks for pics.
frank said to look at that bike but those photos were new to me-well helpful-cheers ;)
o and thanks for bit about runners
a7grenade
gtwildcat wrote:Nice wildcat seat! Wanna sell it?
not at the mo-thanks
gtwildcat
no problem but if you do send me a message, cheers john. :)
    Users browsing this forum: Ahrefs [Bot] and 4 guests
