I have been pleased with the results of the prev spray but it wasnt perfect with some orange peel in places. This was my fault as i didnt rub down either the base coat or the laquer when applying or mop the finished thing with a compound. This time i have more time to spend so would like to try and get a better finish.
Really im looking for advice on a good step by step process to get the desired effect. I have in my head whats the right way to go but iv probably missed a stage out or got it wrong. Also there may be better ways/order to doing pinstrping and secondary colurs?
Using Base coat & laquer: Colour Aston Mart old english pewter, Mini pepper white & pin colour tbd
(using side pannels in this example)
1/ Spray pewter base coat (grab coat + 2 further coats)
2/ Rub down lightly with 1200 (panel wipe & tac)
3/ Mask off areas for white to be sparayed (panel wipe & tac)
4/ Spray white base coat (grab coat + 2 further coats)
5/ Remove masking tape (how long should you wait to do this, until it has gone off or before its fully dried?)
6/ Rub down lightly with 1200 making sure not to go through edge (panel wipe & tac)
7/ Mask off all panel apart from pinstriping and spray 3rd colour (grab coat plus 2 further coats)
8/ Remove tape (same question as 5?)
9/ Rub down lightly with 1200 making sure not to go through edge (panel wipe & tac)
10/ Spray 3 coats laquer rubbing down with 1200 between each
11/ Mop pannel with approiate compound
12/ Polish with correct compound
Any help greatly appeciated
sef
