Boyesen reeds
I don't have a standard cage to compare side by side, and it wasn't explained to me (maybe Diablo could answer this), but it's had work all over the inside, blended and smoothed. How, I don't know, suffice to say though, a standard 350 cage can be improved without the cost of a V-Force and it's replacement petals at frequent intervals.
Diablo
It was a while ago now so I suspect Harry did it. It won't be anything major just flowing the reed cage so it works well with reeds and the manifold.
I've found the normal boysen 2 stage reeds very reliable and much prefer them in rally going TS1s.
Al, it was awhile ago, but I remember you telling me that you bought them as a pair from eBay USA, although not advertised for Lambretta.
mnpes
This may help ~ http://www.shiny-red.net.tuning.guide/47 ;) google it :|
the splits bettween each reed petal looks to have been smoothed as this is naturally a unavoidable restriction
Muppet
don't some remove the unavoidable restriction by cutting it out and fitting boyesen two stage reeds; might destabilise the petals but heard some do this mod,
muppet
C’est la vie
no because the reed would have nowhere to seal against
