TS1 iron liner
Shuggie
Looking for a wee bit of advice.
Got 2 TS1 cylinders that need replating/iron liner fitted. One's a 200 the other a 225.What are my options for iron liner? Like the idea of having a few rebores in case anything goes wrong!!
What are my options regarding pistons as std TS1 pistons don't come in oversizes? Not got a crank yet so happy to get a jap con rod.
Any suggestions?
Train Driver
Alan (Diablo)
07791220193
is dealing with these people for me
Fahron Engineering
Wighay Road
Hucknall
NG15 8AH
telephone 0115 963 4123
They will be putting a liner in my RT barrel
soullad
briefly, you might want to consider the Yam IT / DT piston for the 200 and the KX for the 225. Both offer oversizes if its the rebore / hone feature you're after.
Diablo
Steer well clear of PJME. Precision engineering it ain't
Shuggie
will i need to get the barrel re-worked to use the yamaha pistons or do the pistons need modified?
Supereibar
Get a tuner to prepair the cylinder, piston & head assembly. I am sure they will be able to tell & also modify the piston accordingly. You people are so privileged to have so many good tuners at hand that know what they are doing.
A steel liner sounds great to me as everybody seems to talk marvels about them. Then just tune to taste.
J.
    Users browsing this forum: Majestic-12 [Bot] and 12 guests
