what final gear ratio??
FREAK
Main scooter: Rb225 GP LAMBRETTA
whats the best set up for my bike finding it to die in 4rth
spec rb22 matched cases
af ballanced and welded crank
af light flywheel and bmg 120 watt stator (mag flange machiened to suit)
gp 200 gearbox 19/46 sprokets 4.8final ish
tmx 35
fat mamba (got an nk comming) which is best
ignition at 17 degrees
and ime 15.5 stone :oops: :oops:
1 st and second are mad third is long and fourth if you go into forth any slower than 65 it wont pull
any advice greatley recieved :D
sideout
The RB22 likes to rev, especially with an expansion pipe. I reckon you'd be better off with standard GP 200 gearing. ie: 18/47 sprockets which would give you 5.22 final.
You could still use your existing 82 link chain with that :)
Is it ok in top above 65? If it is, I'd probably leave it as it is.
