Better performance....?
Timbo
Its a scoot i've always wanted whist appreciating it needs to have certain modern components for todays driving conditions.... :D
Timbo; if you want to pep it up a bit and don't want to upgrade your set up you've got to work with what you've got, simple as that. Get the top end off. Look at the ports maybe and sort the rings, overhaul the carb and look at your exhaust. But stop faffing man! :D
joey
...30mm dellorto evergreen filter.....brilliant! cheap/fast/reliable/economical... ;)
Train Driver
joey wrote:...30mm dellorto evergreen filter.....brilliant! cheap/fast/reliable/economical... ;)
Is that great yarmouth
CPH Lambretta
Main scooter: DL 150 1970
Looks more like Margate to me :D
Slow is the new fast!
Smart scoot and fit chick ..and you look at the back drop.. :shock: :D
cezeta
Lam46 wrote:Smart scoot and fit chick ..and you look at the back drop.. :shock: :D
thats timbo, he does look after himself in his later years
cezeta
Timbo wrote:Saw that but want to keep the scoot standardish looking............... 8-)
with the tm(bo)24 you can keep the air box and its the same size as the standard drip feed you have now. rapido 225 http://www.ekmpowershop2.com/ekmps/shop ... -806-p.asp looks standard too and so does the ron moss clubman.
or use the clubman you already have.
tried and tested formular, train driver has buzzed up and down the country and europe on one and same with scooter loopy john......neither are as slender as the girl in the photo above.
its whats going on one of my scooters.......ts1 is going in the bin, more trouble than its worth.
soosh
But surely you ride with your panels on?
How so Joey? A big carb and a ram air type filter? It'll perform, but I thought that always came at a premium?
    Users browsing this forum: Baidu [Spider] and 14 guests
