Advantages of hole in side panel?
Norris1977
Main scooter: GP TS1 1969
Hello. I am running a ts1 with a 34 delorto. Can any body tell me what the advantages are of cutting a hole into the side panel?
sydduckett
Norris1977 wrote:Hello. I am running a ts1 with a 34 delorto. Can any body tell me what the advantages are of cutting a hole into the side panel?
It allows you to get a clean air flow into the carb. Im presuming that having a ts and 34 carb you like to give it some, if you do then this helps apparantley... :D
a hole in your panel not only lets more air in and more efficiently but its the fact thats its also colder or at least cooler air than would otherwise be aspirated from under your panels or through a filter or both ..
Craig H
makes your foot smell of oil/petrol hmmmmmmmmm :frog:
Alternatively, knock a bulge in your panel where the carb is for a bit more clearance, and drill a few holes towards the front of the panel to let air in.
camel
so you can have a ram air filter sticking out
soosh
Run like f@@k down the road for a mile with your hand over your mouth.That's how an obstructive carb feels.
mawso
^^ Ha!
soosh
soosh wrote:Run like f@@k down the road for a mile with your hand over your mouth.That's how an obstructed carb feels.
Norris1977
Thanks for the advice, Next question lol whats the easiest way to cut the hole?
    Users browsing this forum: Semrush [Bot] and 13 guests
