bottom chain guide
Bilko
Main scooter: LI150
Out.
I've never used them.
Bilko's Oily Blog
obviously I've never seen it, but I'd imagine there would be fair amount of lash going on, when shutting the throttle, before the gearbox slows down to the same speed as the crank...
I do generally shorten them a bit at each end.
if you do fit one of the nylon bottom guides, make sure it is carved about enough to allow the chain to run straight...
bazman
Out , never had a problem.
goldeneye
out. after witnessing one snap, and jam the chain solid, on woodys 225 rapido on the way to lincoln for the euro, and it locking the engine solid with no warning, i"m never fitting one again. the uprated top chain guide is all i fit.
probably a better bet would be to fit one of the Teflon ones if only to stop the chain damaging the case
goldeneye wrote:out. after witnessing one snap, and jam the chain solid, on woodys 225 rapido on the way to lincoln for the euro, and it locking the engine solid with no warning, i"m never fitting one again. the uprated top chain guide is all i fit.
I don't bother with the bottom one either for the same reason, never noticed any marks on the bottom of the case.....plenty on the top though
Doesn't fitting a 'pull down' top chain guide negate the need for a bottom one?
red ghost
Main scooter: lambretta gp150
In and funnily enough it's something I bought from mr. tino that works ;)
stew
Main scooter: Series 1 and series 2
red ghost wrote:In and funnily enough it's something I bought from mr. tino that works ;)
:shock: :shock: :shock: :o :lol:
Only use top guide
Loud pipes save lives!!
red ghost
There are only some who are smarter than the Innocenti engineers..
So, use both, it's better value for money(if bought as a pair)... and as intended by the said engineers.
And just to reinforce the point, would you remove a chain guide from your car?
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
