f***ing five plate?
mickdale
took my 5 plate clutch out as it was slipping
5 x surflex corks @ 2.5 thick
steels @ 1.2 thick
2.5 top plate
total 23.5 mm thick whole clutch inc bottom clutch flange
got a five plate clutch kit, soaked corks then went to put in and it wouldnt even go down so i could get the clutch circlip on
no room for movement there then :roll:
had a look and the surflex corks are a whopping 3.63mm thick!!!!!!!!!!!!!!!!!
is it just my set up that is shite or are surflex b corks that are 3.63mm ick the problem????
any help GREATLY appreciated
mick
ps the rear sprocket is a five plate one
rocho68
Is it s five plate spider ?
mickdale
rocho68 wrote:Is it s five plate spider ?
er no.....
if i find one and put it in will the clutch foul the kickstart mech?
ps where do i get one from
fred
3.5mm is standard 4 plate thickness(14mm for 4 plates)to fit 5 standard surflex plates,ie the ones used in 4 plate clutches you'll need an extended spider,and an extended clutch bell.
I'm using a scootrs spider with a 5 plate crownwheel,and a mb bell. Doesn't foul on anything.
mickdale
phew - so i can do it with a longer spider and clutch bell
fred - did u get the scootrs spider from viet or uk source?
mick
10 inch Terror
Xbox live gamer tag: No.
fred wrote: I'm using a scootrs spider with a 5 plate crownwheel,and a mb bell. Doesn't foul on anything.
I'm using the scootrs crownwheel and spider and a deep bell from beedspeed. It all works well together. You should be able to source the whole lot from the UK.
soullad
or go thinner steels.
I have a surflex b (3.5mm thick) 5 plate with 1mm steels and standard crownwheel, scoot rs spider and intermediate length uprated springs.
mickdale
THANKS EVERYBODY
ive found the longer spider and bell fom beedspeed for 50 quid
    Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
