Ever seen one this bad? Update. It gets a lot worse.
giankx
Usually a Breathsweet Tino filter doesn't affect performance and jetting, so i always use one.
Expecially on dirty and sandy roads down there in Italy.
leigh
wack 63 wrote:The bad thing is you can replace the slide etc but I think the plastic guide in the carb is not available so the slide still rattles around,but I could be wrong.Where was your mate riding ,a desert?
http://www.dellorto.co.uk/merchandise/p ... ctionID=33
lifes a drag
sean brady scooters wrote:well just give Eden a pm if you like ,hes tried his with and without ...but as i say ..if filters make NO difference to performance then why oh why arnt all the racers using them hey ?
i just thought it would be easyer for you to show us one seen as you would probably have accsess to a dyno more than most, granted anything that obstructs flow will affect performance but what about the affect that air flowing past the opening of a carburetor at say 50 mph to that of one with a more stable flow with a filter on, surley air going past the carb opening at speed will have an affect on fuel being sucked out just as much as being sucked in wont it . im not having a go at you so please dont spit your dummy out because iv questioned your knowladge, :lol:
the effect that you refer to "air rushing past the carb opening" is SO slight that its almost insignificant and imperceptable at say 50 mph ,but rather interestingly at much higher speeds this effect can be used to enhance performance by slightly pressurising the inlet tract just like yamaha/kawasaki etc did by using the ram air systems ..so a forward facing carb or bellmouth etc could work better ...but the trouble is that you need to be doing at least a ton before this even starts lol
I ditched the breathsweet as it strangled the carb tb h, it certainly is more responsive at all rev ranges open and sucking ..lol..
Thanks for that Leigh,just that I was told a while ago by a well known dealer said they weren't available and sold my mate a brand new carb instead. When I had a scoot dynoed with a Mallossi filter it made 14 hp then 17 removed so it proved to me that they do restrict air flow
lifes a drag
just look at how mutch fuel is leaving the carb here,
http://youtu.be/fVM3vMylehA
soosh
I've never run a filter on any of my kits and have never seen that kind of wear.
Maybe if lived by a quary.
lozmondo
Thats my 35mm TMX on a TS1 WOT on a dyno. Never run a filter but had to change the rings after 7500 miles
lifes a drag
lozmondo wrote:Image
looks like you have that dialed in then,, dont think id leave a 2 stroke 7500 miles before a ring change though :shock:
    Users browsing this forum: Amazon [Bot] and 2 guests
