Worst worn slide I've seen.
I haven't much experience with worn slides, what are the symptoms?
It was running ok, but a bit lumpy low down. I would have thought it would have run lean, but seems not. I suspect the needle is well worn as well and may be compensating.
Any thoughts anyone?
