p200 floor runners
Twinny
Main scooter: suzuki 185
can someone advise please
fitting some new runners to p2, the kit comes with these rivets,never done vespa,s before,is there a special tool to fix rivets or a hamer job
cheers john
gaz_powell
Twinny
i never use the supplied rivets as they are a pain if and when you want them off. Use small ss nuts and bolts/screws with a flat head. I then drill the plastic end caps.
gary
sydduckett
Twinny wrote:can someone advise please
cheers john
Get the hammer out...you know u want to.... :D
vesbrettas
the rivet the kit comes with are the wrong ones, piaggio use pop rivets all from the top apart from the end caps which are from the bottom i use short 3mm on the runners the 4x10mm on all the end caps apart the two buy the legshield trim which are about
4x13mm hope this helps
Twinny
thanks for replys (apart from sid bucket lol) i have used nuts and screws but would still like to know if there is a special tool for supplied vespa rivets
thanks
squeakmillward
Twinny wrote:thanks for replys (apart from sid bucket lol) i have used nuts and screws but would still like to know if there is a special tool for supplied vespa rivets
thanks
its not a special tool as such just a normal pop rivet gun fitted with a longer "nozzle" so that it will sit in the runner,available from any tool warehouse
