MPG rapido 225
Eibar
Main scooter: Eibar TS1 1966
I'm only averageing something between 30-35 mpg with 28phbh, av266 x7 p1,122 main - shocking in my opinion.
potato
phil23fair
I have a Rapido 225 with a ScootRS exhaust and 30 mm dellorto and my fuel consumption is about the same as yours, however I do tend to ride with the throttle wide open whenever possible. Less right hand might see an improvement, but not half as much fun.
goldeneye
about the same, 70-80 miles per standard tank on a run. throw some hills and wind into the equation, and its less. ive only got a sixty mile arse, so ive gotta get off anyway. what gearing you got in it?
Eibar
5.0 ( glad I changed to 5.0 for kelso journey) did have 4.6 in but to sluggish for any real riding and the motor sings nicely with 5.00
potato
monkey boy
Hi is that a classic or race and what pipe?
Al
Dazza
45mpg roughly on mine
Eibar
classic
NK rapido rally (similar to ADS pipe)
potato
monkey boy
My set up is
225 Rapido classic,4.8 gearing,48 clubby 28mil phbh unfiltered and jetting currently 50 pilot,AV264,X13 second clip down,122 main.
Been doing plug chops and tinkering with jetting for most of the day.
Havent got any solid mpg figures yet,but was gob smacked when I opened the tank tonight.Pretty much empty.
The plan was to move onto AV 266 and X7 needle combination in the morning cos the above setting is just a bit too light on the plug colour for my likeing.
Dunno if I dare after draining the tank as quick as I have done today.
Think some advocate the use of Mikuni TM24 carbs for economy.
AL
mikeallen
Xbox live gamer tag: junkyevenflow69
Also running a classic Rapido 225 with 30mm phbh with filter, 42mm clubman, 4.8 gearing.
I tend to get approx 70 miles on a standard tank.
Train Driver
17/46, Li150 box, 24mm mikuni, ancillotti exhaust when i had my classic rapido and i used to get 50/60 mpg.
It was set up and dyno'd for motorway cruising.
Now with an RT kit i get the same mpg but with an increase in acceleration and top speed
