servetakid wrote: I was looking at Imola kits and they seem to put out some decent figures. So i was wondered if any one could suggest any other kits or what works we'll with the imola kit. I'd want something that will be faster than my T5, nippy round town and would hit around 75mph without sounding like it will blowup!
cheers.
From that statement I think the Imola will do what you want. Your choice of gearing though is very important, mine used to be 5.7, it was brilliant and brought a smile very regularly on the lanes around where I live but was a bit of a pain on long fast runs. It's now at 5.3 and that hasn't really reduced the fun factor locally but has improved it on longer runs. It will run with the pack no problems at at 60-70 and still have lots left for when you need it, it will however sound like it's gonna blow up but it won't! I don't know the top speed of mine as my balls seem to have shrunk...
On 4-5 hour runs though it's a bit of a pain, I get fecked off with the revving and the vibrations and tbh would much rather be on my GP200 for those trips. I'm going to see if it will pull gearing of 5.0, if not it will get left at home for the longer trips.
I've done 12000 miles on mine and only stripped it twice, changed the rings the first time (some blow-by) and currently it's in bits because the weak point was a circlip... very reliable and relatively low maintenance imo. Carb is a 30 delly, pipe is a JL3.
/edit
The acid test is would I buy another, I may well do that and sell my damaged kit for someone else to fix, I've looked at the options and cant see a better buy.
