re made gearchange
ts200
i've got one of these recently remade series 3 gearghages,
i am doing a dry build on my gp a the moment and as i was building the headset i noticed that where the clutch cable sits inside the gearchange there is only a slot,
it's not like a proper gearchange where there is an actual round cut out for the cable to sit in,
has anyone come across this?
does it work as is, or do i have to somehow drill it as per original?
we would need to see from the other end i think
I just looked at a couple of new ones and they're the same, I'm not sure if it'll serve any purpose drilling a recess for the outer cable end to sit in as once it's tightened it can't go anywhere.... can it?
ts200
corrado wrote:I just looked at a couple of new ones and they're the same, I'm not sure if it'll serve any purpose drilling a recess for the outer cable end to sit in as once it's tightened it can't go anywhere.... can it?
true, i'll try it as it is
cheers
RBG
Is there not a chance of the inner-cable rubbing & then failing?
The inner needs to be kept central does it not?
    Users browsing this forum: Baidu [Spider] and 13 guests
