Breaking up at just over 6000 revs
storkfoot
Fair point, Col. And, yes, I' m damn certain there are plenty of very revvy Lammy engines with Ducati CDIs with no issues at all. But maybe, just maybe........ it does fix it and I don't have to lash out more hard earned cash.
Ah, the power of positive thinking ;-)
camel
when you say "breaking up"....are you talking about a misfire? or power dropping off?....just out of interest what pipe are you using?
storkfoot wrote:... there are plenty of very revvy Lammy engines with Ducati CDIs with no issues at all....
my bike is quite revvy and have been using Ducati CDI for 000s of miles; as you say, I am sure I am not alone in that.
just try that Indian flywheel...
leigh
Have to agree, had an AF on my RB started missing at High revs. Put a JB jobbie on there ie machined Indian, cured.
storkfoot
camel wrote:when you say "breaking up"....are you talking about a misfire? or power dropping off?....just out of interest what pipe are you using?
It's defo a misfire**, you could see it happening on the dyno. Pipe is a '90s Taffy Road so the equivalent of a JL3
Edit: I don't mean a misfire in the "backfire" sense, it's more like it just doesn't fire at all when it gets to a certain revs
soullad
try a different regular SIL Indian flywheel mate.
storkfoot
soullad wrote:try a different regular SIL Indian flywheel mate.
:D , this seems to be a recurring theme, Ian ;)
I tried an older AF flywheel without the spacing washer today but still with the brass rivets. Unfortunately, it wasn't a known working flywheel. Again, it seemed to break up in roughly the same place :(
mac
Had the same problem on my RB with a AF flywheel tried different stators, CDI's etc and was still the same
Changed the flywheel to a SIL one problem solved.
mickdale
definitly a recurring theme................
storkfoot
storkfoot wrote:I've spoken to AF who did say this has happened before with their light flywheels and Ducati CDIs which are designed to run on low"ish" revving Vespas. They do an "AFR" CDI which they believe may solve the issue. To be fair to them they did warn me of this when I bought the flywheel 18 months ago. Anyway, I've got one of them on order too.
Just tried the AFR CDI. Still the same. Will get hold of another flywheel next.
