Just to update this. Replaced the pick up with a genuine Vespa one tonight. No difference.
I'll give AF a call tomorrow and see if they have heard of this problem on one of their later light flywheels
Breaking up at just over 6000 revs
By chance do you have an MB digital speedo installed?
red ghost
- Xbox live gamer tag: Pleasure Master
- Main scooter: lambretta gp150
Could be your HT lead or supressor cap, I've had simular problems with cars over the years..
just to confirm its an AF LIGHTENED FLYWHEEL as in new version of the vega flywheel/ducati type - not a SIL flywheel
storkfoot
Yep, it's definitely the light one.
I should be getting hold of another flywheel over the weekend, so I'll give that a go and see whether that indicates that the problem is flywheel related.
I've spoken to AF who did say this has happened before with their light flywheels and Ducati CDIs which are designed to run on low"ish" revving Vespas. They do an "AFR" CDI which they believe may solve the issue. To be fair to them they did warn me of this when I bought the flywheel 18 months ago. Anyway, I've got one of them on order too.
Thanks again for the ideas
definitly the flywheel - had the exact same problem with mine a few years ago - and was at 6000 rpm aswell
changed allsorts
machined magflange / flywheel etc trying all permutations
read all the forum info - there was a great thread on this i think on the old lcgb site - some guy really looked into it
in the end i put a normal sil flywheel on and voila! - all problems gone, just a load of spare duplicated ignition parts i'd bought
changed allsorts
you should have had it Dyno`d Mick.mickdale wrote:definitly the flywheel - had the exact same problem with mine a few years ago - and was at 6000 rpm aswell
changed allsorts
win or lose have a booze
- coaster
storkfoot wrote:I've spoken to AF who did say this has happened before with their light flywheels and Ducati CDIs which are designed to run on low"ish" revving Vespas.
Errr....what about T5's, they must rev to 8 or 9k or so surely? The CDI on mine 'looked' exactly the same as any other Ducatti CDI except that it was black
