chain lengths
simon k
after reading a guide on a dealers website i tried to fit an 82 pitch chain on 19/46 sprockets and it was loose as f**k. will 82 pitch fit on 20/46?
cheers simon
yes m8 just done the same as well
rog60
Main scooter: Indian GP200
Thought it had to be a 'stretched 82' for 20/46. Ref 19/46 I had to use an 81 link or reduce your 82 to 81 link might be cheaper than buying new sprockets.
Any other thoughts from anyone else. :?: :?: :?: :?:
J1MS
rog60 wrote:Thought it had to be a 'stretched 82' for 20/46. Ref 19/46 I had to use an 81 link or reduce your 82 to 81 link might be cheaper than buying new sprockets.
are you fitting the chain to a new set of sprockets...?? As Ive run 19x46 with an 82 pitch chain with no probs....
I just thought the sprockets could be worn Maybe... I hope you sort it All the best 8-)
im using all new . guess i will have to try a 20 tooth one :cry:
davidblythe
19 46 on a 82 link chain does go when everything is new, but it seems to me to be the slackest fit of all the combinations esp compared to 18 47 with a 82 link chain
or 16 47 or 17 46 on a 81 link chain
we just did a 20/47 and it was very tight so should be ok with 20/46 .
anyone want to buy a 19 front sprocket?
simon k
new indian front sprocket, new mb crownwheel.tried three 82 pitch chains. new iwis, indian one & one other( not sure of brand) all new. tried taking one link out of the last one, too short!
going to try a 20 front sprocket tommorow on 82 pitch. or if anyone has a stretched 81? :)
Richy roo
Main scooter: Lambretta GP TS1 225
have fitted 46x19 sprockets with a new IWIS 82 chain and all was fine, have done about 300 miles on new set up and had the chain case removed for chroming and the chain is as loose as hell. Any recommendations on what to do? i have a standard ts1 top end with a JL3 pipe so will consider changing sprockets but need to keep correct ratio
Did you you check your sprocket heights when you put it back together? If they are out it can wreck a chain real quick.
    Users browsing this forum: Google [Bot] and 14 guests
