65mm stroke options
grimspeed
Main scooter: gp 283 kx
there are now!
Chris CSPE
Does worb5 still do there long stroke cranks Eden?
dirtyhandslopez
Won't be any casing left to hold it together after cutting for webs that big:shock:
That's not going anywhere...
Chris CSPE
The webs don't necaceraly need to be any bigger, it's the steped big end pin that moves the rod further out to gain a bigger stroke.
grimspeed wrote:there are now!
So what are they?
grimspeed
jerome offerd to do me one using one of his 64mm jobs as a start.
decided after talking to him to stick at 64mm. with a js 550 piston!
smaller piston is 70mm larger one js 550 kawasaki jet ski 75 mm.
i have a 80mm spigot. the cylinder is a air cooled kx 250
grimspeed wrote:jerome offerd to do me one using one of his 64mm jobs as a start.
What is cost of that crank/piston combo if you dont mind me asking?
grimspeed
just short of £300 for the crank and look on ebay for the piston you can pick up wiseco ones dirt cheep!
wax
Can Readspeed fit one of their eccentric pins to a 64mm crank? That would be 67mm stroke! MONSTER!
    Users browsing this forum: Google [Bot] and 12 guests
