Cutting a hole in my side panel for carb ?????
wellersmate
Main scooter: lambretta li150 special
Is it really necessary or does it not make a major diffrence?
wellersmate wrote:Is it really necessary or does it not make a major diffrence?
Have you ever done a run with an S10 respirator on?
wellersmate
Ha, who do I go to, to get a hole cut out do you reckon ?
i depends how much you want to cut a hole or if you need to for clearance and i am assuming you mean for the fitting of a larger carb
....but you can look at it two ways ,
hole = fresh cooler air ,
or no hole = hot dusty air from under the panels that has already been preheated via the fan and cylinder cowlings
I don't have a hole for mine. I've just knocked it out a bit so there's more of a gap between panel and carb. A couple of holes near the front of the panel, so you've got some air going in, was what the dynoman recommended when I had mine set up. It runs alright without, so I've not bothered.
wellersmate wrote:Ha, who do I go to, to get a hole cut out do you reckon ?
Do it yourself.. :)
wellersmate
I haven't got a steady hand lad or I'd have a blast :p cheers for the help might go with a few little ones nearer the front
wellersmate wrote:I haven't got a steady hand lad or I'd have a blast :p
Use an angle grinder then :)
poose
Mine runs fine without a hole in panel.
Dazza
Run it without a panel on and try and see what you think, been pondering over this myself, mine does seem ok, I have my carb as far back as it will go so a decent gap but i get a few quids worth of oil over my rear runner after a run, at least if i cut a hole in my panel my jeans would soak it up :D
Use one of these matey - straight through no messing:
Just take your time, plenty of WD40 or similar..
    Users browsing this forum: Google [Bot], Semrush [Bot] and 35 guests
