super wide rear
http://www.facebook.com/?closeTheater=1 ... 26&theater
ill sort a pic in a bit for the non fb peeps :D
RICSPEED wrote:http://www.facebook.com/?closeTheater=1 ... 26&theater
This site is blocked by the SonicWALL Content Filter Service. :cry:
Dell Oughta
here it is
soullad
looks great.
what top end is that, YZ or KX ?
what crank are you running and (then in a penny drop way) what ignition too?
hope you don't mind me being nosey .... cheers
twin
hows that done, has the engine been off set,
Wayne Miller
Heres another one but from completely the wrong angle :ninja:
Stay tuned..............
i Attempted this myself a while ago,and the way i did it was to alter the frame mountings by 1cm ..so as to offset the motor to the offside..
i then used vespa rims,welded and re drilled and a 1cm spacer as per the SIP technique.. :D
it worked out really well and i found that all was kept central and in line with minimal mods to the mag flange whilst keeping the std rolling radius of a 3.50 tyre...
but i,m sure that wider tyres could be be fitted if only lower profile ..interesting to see how this all works out .
soullad wrote: what top end is that, YZ or KX ?
i did ask but he didn't say ...the rims are a proto at the moment
i shall have to ask about top end again ....the fly wheel looks to be a vespa one but thats merely a guess
