T5 classic forks
Tosh
Please please Please could someone tell me how to get the pivot pin,bearing,seals out of the suspension link at the bottom of the forks. Need to replace them got a bit of play there. Thanks Paul
ABC
Main scooter: mk1 t5
use a hydrolic press (a local garage will have one for bushes and bearings)and a long 8mm socket . the socket will press through the bearing and push the pin through and remove the link.. replace the bearings and pin as a set
wack 63
Main scooter: '71 GP TS1
Piaggio dealers should have a tool to do this job without removing the forks.I have used one before but it really needs two as it is awkward to use on your own.
Tosh
thanks for that chaps, so you put the socket over the center of what looks like a castle like spring clip and just push through to the other side am i right in what i`ve said
Fruitjuice
You will need to remove the spring clips on both sides before pressing out the pin...
Life shouldn't be a journey to the grave with the intention of arriving safely in a pretty, well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, loudly proclaiming: "WOW, WHAT A RIDE"
Tosh
ta fruitjuice, whats the best way to remove the spring clips as they are very strong and i can`t seem to bend the tabs up to release them
Fruitjuice
Hammer and a small chisel to break off several of the tabs, then try to prie it out with a strong screwdriver...
Tosh
once again fruitjuice thanks allot be in garage tonight to strip down sons forks and wait for parts from beedspeed
    Users browsing this forum: No registered users and 25 guests
