SERIES ONE FRAME BREATHER(scooterotica forum bitza )
OK with bits sourced off various members(off here and other forums) i now have the most important bit .......the frame
1958* 125 frame breather
i don't expect things to move to quick unless i lash it up in satin black for a while as i have a house to renovate first then build a garage before i can even think about a build..... not to mention a GP to finally finish :roll: :lol:
(*to be confirmed,need cert)*edit
*came back as 1959 weirdly :?
ps i will be on the look out for bits ....but major purchases will have to wait as my c/c has took a hit :lol:
edit ........if anyone has a scrap s2 horncast that i can cut bits of to repair the s1 cast(bottom mounts)
forks from el markio
led rear light ....
bit of a lash up but ill see how it goes :D
MADSPEEDRB260
Main scooter: lambretta gp200
8-) Im just doing a Madspeed series 1 looks good mate.
Robi D
How did you do your LED taillight? looks good so far BTW.
Robi D wrote:How did you do your LED taillight? looks good so far BTW.
it was this type -
sure you can get them cheaper ,motrax i think but i had it given a few years ago and was just sitting in a drawer so i just removed the led/circuit board and mounted on brass computer motherboard standoffs ..ill try rig up a 12v supply and try it
how about two of these ?
only thing this would not light the reg plate very well
or this?
STA48209 by ricspeed71, on Flickr
showing reg plate lights on under side
tail
stop
    Users browsing this forum: No registered users and 65 guests
