Mickek Exhaust Bracket
windhit
Main scooter: lambretta imola gp
Hi does anyone have a picture of a MKV Mickek exhaust fitted as im missing the rear bracket and need to know where it mounts.
Cheers
Steve
most mikek pipes fixed to the shock bolt
windhit
RICSPEED wrote:most mikek pipes fixed to the shock bolt
Thanks for the quick reply RICKSPEED.
Ive bought a Imola engine with this pipe fitted but minus the bracket.
I was hoping somebody on here might have one fitted so i could copy and fabricate one,Or maybe buy a similar one off the shelf.
Steve
is it the pipe with the long thin alloy can, or the more DJ-esque one ?
I can take some pics of mine [with the alloy can] if it helps.
In fact, it's off the bike just now, so can take some measurements.
windhit
byron wrote:is it the pipe with the long thin alloy can, or the more DJ-esque one ?
Hi Byron thanks that would be great.
I have the other type but a pic would be great as i dont have any pice of shocker mounted pipes.
The only thing i have on this one is a bobbin and a piece of bent steel which makes me think it was on a cut down before.
Steve
best i can do at the mo ,but its just a flat section of steel bolted to the shock bolt ,you can see the rubber mount under the end pipe
my end can bracket :
there's a metal strap round the can that fixes via a bobbin to the bracket :
If you're starting from scratch, get the pipe where you want it and make a bracket to fit.
windhit
byron wrote:my end can bracket :
Thanks Byron thats great although my exhaust has the bobbin welded on and is further down the pipe.
It looks the same as the picture but is powder coated black and appears shorter,so im not sure which model it is.
Steve
    Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 10 guests
