Chaincase Breather?
Posted: Sun May 09, 2010 11:16 am
by westburyst
Do these have any sort of filter in them?
Ben
Re: Chaincase Breather?
Posted: Sun May 09, 2010 11:38 am
by desi
Mine does - a disc with a half moon cut out holding what looks like a tuft of fibreglass if that's any help - can't say if that's the norm mind.
Posted: Sun May 09, 2010 11:48 am
by westburyst
Thanks desi, I think it is normal to have that inside mine has it too.
Can this be taken out and cleaned?
Posted: Sun May 09, 2010 11:56 am
by bristolmod
the original ones had wire wool inside- these tended to block easily over the years, thus creating pressure in the crank case (= possible blown seals). I've always tended to remove the wire wool in its entirety, thus allowing the crankcase to "breath". No real problems with oil coming out.
Posted: Sun May 09, 2010 12:07 pm
by westburyst
Chris, how about the possibility of dirt getting in?
Ben
Posted: Sun May 09, 2010 1:34 pm
by bristolmod
never thought about that!!
To be honest, the hole is pretty small, and you stand more chance if you run an open mouthed carb IMO.
I use a small twist drill to pull out the wire wool; flush it through with parafin, then replace on crankcase.
