Chaincase Breather?
westburyst
Do these have any sort of filter in them?
Ben
SIL GP200 92'
I've lost count how much I've spent.
desi
Mine does - a disc with a half moon cut out holding what looks like a tuft of fibreglass if that's any help - can't say if that's the norm mind.
westburyst
Thanks desi, I think it is normal to have that inside mine has it too.
Can this be taken out and cleaned?
SIL GP200 92'
bristolmod
the original ones had wire wool inside- these tended to block easily over the years, thus creating pressure in the crank case (= possible blown seals). I've always tended to remove the wire wool in its entirety, thus allowing the crankcase to "breath". No real problems with oil coming out.
Chris
Scootering since 1968.
westburyst
Chris, how about the possibility of dirt getting in?
Ben
SIL GP200 92'
bristolmod
never thought about that!!
To be honest, the hole is pretty small, and you stand more chance if you run an open mouthed carb IMO.
I use a small twist drill to pull out the wire wool; flush it through with parafin, then replace on crankcase.
Chris
