Toolbox Rubbers.............
rog60
Main scooter: Indian GP200
Can anyone recommend a supplier of toolbox rubbers that are soft enough to be bent round the toolbox corners fairly easily. Just tried to fit one from Camlam but had to cut the rubber for a good fitting on the corners. (tried the hot water softening trick)?????????????
Timbo
rog60 wrote:Can anyone recommend a supplier of toolbox rubbers that are soft enough to be bent round the toolbox corners fairly easily. Just tried to fit one from Camlam but had to cut the rubber for a good fitting on the corners. (tried the hot water softening trick)?????????????
..............discussed here recently and have a look at the video.... 8-)
http://z3.invisionfree.com/WKFA_SC/inde ... topic=3544
