scooter loopy QA. help
caspa2006
has any body fitted one the these scooter loopy QA throttle roller to
a set of scooterRS drops if so have you got any pictures, I have tried
mine again today and it seems the standard throttle bar is short by 1/2"
or do i have to grind out the headset for the QA to turn correctly and
make by own throttle back stop. it does fit ok in a standard headset or
is it just the RS drops
pompeyts1
I have one on my scootrs sx drops , I did have to alter the stop a little bit and changed the angle at which the throttle cable came through the guide hole to stop it rubbing ,but it wasn't to much aggro! cant post a pic due to threads on my headlight rim not being to good and dont want to strip them sorry!
caspa2006
cheers mate i thought it was me and i have got the wrongs rod or
some thing like that now i know i will grind the headset down abit
cheer again
