gp headstock stuff
C*NTSPEED
i need the race and bearing kit for the forks is there a better brand or are they all as good?
i seen a kace set up and a swedish industries?
GEMINI S.C.
BLACK WIDDA'S S.C.
J1MS
You can improve the steering a little over standard by discarding the race bearings and fitting loose rollers (tricky but worth it) 1/4 inch balls for the lower 1/8 balls for the top, and they are available from most bearing stockists...
C*NTSPEED
i need the locking rings and so forth but will give that a go
GEMINI S.C.
BLACK WIDDA'S S.C.
