TS1-200 Yamaha info req.
TS1-200
I`m about to check for wear on my Yamaha IT175 pistoned TS1-200, to check ring wear what sort of ring gap, when I put the rings in the cylinder should I be looking for as normal, so I can tell how much wear there is on the rings, and whether they need replacing, assuming there is no other obvious signs of wear.
Keep on keepin on
    Users browsing this forum: Semrush [Bot] and 15 guests
