26mm phb carb
Posted: Tue Apr 20, 2010 6:54 pm
by oggy
Is the setting of the air screw the same as on a std carb,about 1.5 turns out ??
Re: 26mm phb carb
Posted: Wed Apr 21, 2010 9:00 pm
by DaveInPortland
Yes.
Re: 26mm phb carb
Posted: Sat Apr 24, 2010 7:10 am
by Special X
No!!! there's no fixed setting. If you use the correct idle jet you will find it "dials in" somewhere between 1 and 2 turns out. Very important to get the idle mixture right as this has implications all the way up until you are on WOT.
